Conversational Language Understanding (CLU)
Natural Language Model
Your CLU App performs the following functions:
  • Records what questions or phrases (called "utterances") users enter into the search query
  • Interprets the question or phrase ("utterance").
  • Describes the meaning of the question or phrase
A model includes:
  • Intents:
    • Tasks or actions the user wants to perform.
    • Enter intents into your CLU app.
  • Utterances:
    • Examples of user inputs that your app is designed to interpret.
    • Each intent requires examples of user utterances.
    • It may be a sentence, such as:
      • "Book a ticket to Paris for me"
        or
      • A fragment of a sentence, like "Booking" or "Paris flight."
  • Entities:
    • A specific word or phrase inside an utterance that you want extracted, such as:
      • Names
      • Dates
      • Product names
      • Any significant group of words
    • The primary purpose of entities is to give the client application predictable extraction of data.
    • An optional, secondary purpose is to boost the prediction of the intent or other entities with descriptors.
Examples
SearchForKnowledgeArticles Intent Example
  • In the example below, the intent "SearchForKnowledgeArticles" is shown.
  • Every line contains an utterance.
  • Entities in each utterance are highlighted in blue.
  • Note that entities such as IssueType, OperatingSystem, and Devices are a kind of keyword that can be recognized by your app.
How to Train your CLU App
  1. Select Training jobs from the left menu.
  2. Select Start a training job
  3. Enter a model name
  4. Select Train
How to Deploy your CLU App
  1. Select Deploying a model from the left menu.
  2. Select Add deployment
  3. Enter a deployment name
  4. Select your trained model from above step
  5. Select Deploy
CLU Settings
The NLQ Service Configuration page can be found by accessing the NLQ Service Settings page from the Administration page:
Not every query reaches LUIS.
By default, only queries with at least 3 words reach LUIS.
Note: At least 1 one the 3 words must be a stop-word.
A built-in memory caches questions that are asked multiple times.
If the following settings are changed (such as lowering the value for the Minimum number of words in query necessary to be NLQ), then LUIS is called more often and the quota is reached faster:
  • Minimum intent score
  • Minimum number of words in query necessary to be NLQ
  • Minimum number of stop words in query necessary to be NLQ
The administrator needs to complete the following fields from NLQ Service Configuration page:
  • Endpoint
    • The NLQ Service Endpoint.
  • API key
    • The purpose of the key is authoring
  • Project Name
    • CLU Project Name
  • Deployment Name
    • CLU Deployment Name
  • Trained Model Label Name
    • CLU Trained Model Label Name
  • Maximum query length
    • Maximum query size.
  • Supported Source IDs
    • Enter the result source IDs, comma separated, which invoke the call to the NLQ service.
    • Example: b29924a9-ec32-4c10-8892-a544b69ee121,b09a7990-05ea-4af9-81ef-edfab16c4e31
    • Indicates the minimum prediction accuracy for intent.
    • A prediction score is between 0 and 1.
    • Is an integer.
    • Is an integer.
    • A stop word is a commonly used word (such as “the”, “a”, “an”, “in”).
